The Xbox 7MN-0001 Wireless Controller, was manufactured by Microsoft Corporation. It is the first generation Xbox One controller released, but has since been discontinued. This controller has since been superseded by Models 1697/1698 and Model 1708. While this controller is commonly used with the Xbox One, it can also be used for PC gaming.
Why won't my controller turn on?
Sometimes the Xbox One controller will not turn on, even after replacing or recharging the batteries.
Score 55
55 Comments
My controller had a venom battery pack in it and i put in a charger that didnt work with the battery and now my controller is not turning on. Can anyone help me
by
Same. I had a venom pack it bent it and stopped working
by
Turned my x1 controller on the light dimmed after a moment then just stay off. Put in a fresh set of battery's same issue occurred. I plugged it in via USB stayed in for a moment then turned off. First time this has happened. I've got hardly any interference using only one wireless controller. I'll end up pulling it apart to see if it needs a cleaning or repairs. In the middle of playing mass effect Andromeda really wanna get back into it. Anybody figures out anything keep me posted :)
by
My Xbox One controller still turns in, but I can't tell bc the light on it doesn't work... And it also turns off the second I turn it on and start using it. I can't find any website to help.
by
My Xbox one controller wouldn't turn on since i tried to update it in settings.
by
Show 50 more comments
Add a comment
Chosen Solution
My controller died during an update and would not turn on no matter what I did.
I fixed this issue by using a known good USB -> Micro USB cable from my phone charger, and fresh batteries in the controller (do NOT assume your cable is okay - try another one if you have it). Turn off the Xbox One and unplug it for a minute or two. In the meantime, plug in the controller using the USB to the side port (probably any port will do, but that's the one I used). Plug the console back in and turn it on using the button on the console, not the controller. After a minute, the light on my non-functioning controller lit up and all was good to go.
Good luck, hope it works for you too!
If you continue having issues turning on your Xbox One Wireless Controller, check out this Xbox One Wireless Controller Won't Turn On Problem Page.
Score 64
52 Comments:
this happened to me and your info helped. after a few minutes plugged in. it came back on. thanks buddy!
by
Your fix worked - saved me from buying a new controller. Thanks.
by
Might try this on my bricked (repaired connector, it worked for about 48 hours then also died during an update) controller. Wonder if a higher pin number sold with some newer phones will work? I think it might be a timing issue. Will do some more tests with the SDR# and tape antenna on the chip in case I can ID the exact point at which bootup fails. (related hack: do the same to a dead microSD card as its possible to extrapolate data overwritten if expected pattern is partially known though incredibly slow)
by
Thanks for helping get my controller working again!
by
This worked for me! Thanks!
by
Show 47 more comments
Add a comment
Score 17
13 Comments:
Dude you saved me a beating thank you so much im so grateful
by
Only thing that worked! You are a hero
by
Thanks for the post did the job for me went through 2 sets of batteries and then tried this method and it worked.
by
Worked!!! thanks brotha
by
You're the man, much appreciated!!
by
Show 8 more comments
Add a comment
If your controller won't turn on, first try replacing or recharging the batteries. If that still doesn't work, your charge cable may be defective, and may not be charging your batteries. Check out the Xbox One Wireless Controller troubleshooting page for more information at Xbox One Wireless Controller Troubleshooting.
Score 6
3 Comments:
Wow it actually fixed my controller now me and my sister could play together now
by
I did a new battery pack wont work tried to connect from controller to xbox wont work and when I use a USB cord wont work it's just trying to connect to the xbox
by
It worked thank you so much I have been trying for an hour.
by
Add a comment
I bent the battery tabs back outward,, they get pushed in over time causing poor contact. Restoring the spring action of the tabs fixed the issue.
Score 3
1 Comment:
Thanks for helping me, I was going to take it to my neighbor who works on electronics, but I read this and tried it, and it worked. I can't thank you enough!
by
Add a comment
The same thing happened with me but I looke at my Xbox and saw it wasn't on unplugged everything plugged it back in Xbox turned on and the controllers started working
Score 2
3 Comments:
I tried 4 times and it doesn't work wtf
by
Same here, I tried everything he did and still nothing.
by
Do you even know proper english? Do that first before telling us something everyone already knows or tried...
by
Add a comment
I have had no problems with my xbox had it since the kinect first came out since then i played with power packs on my controller and the for some reason it stopped connecting after that a bought a wired controller used that then soon didn't wanna work either then i said ah what the hey i bought a another wireless controller worked for a bit then battery pack stopped working so switched to rechargeable batteries now controller does not turn on what so ever no power no sync nothing i tried with a power cord nothing fresh batteries nothing. Tried power cycling the xbox and nothing i am at a loss now way to controll my xbox i am losing my mind and keep in mind i have only had this $64.00 controller for 3 months
Score 2
Add a comment
This happened to me. Xbox one controller dead, even with new batteries, I thought it was goosed, what I did was took the batteries out, plugged it in to the xbox and kept pressing the middle x button that normally lights up when connected, nothing happened at first, then after about 30 seconds of repeated pressing the x miraculously lit up, I disconnected it from the cable, replaced the batteries & it now works as normal, hope this helps someone.
Score 1
2 Comments:
\\\\absolutley horseshit
by
|dont freaking swear
by
Add a comment
Try putting the plus poles on the plus side and minus on the minus poles.
This can solve your problem.
Add a comment
It could be a physical problem, water stuck in the controller or otherwise.
Add a comment
So I just fixed this problem incase anyone runs into it in the future. Just unplug your Xbox for 5 mins and try again. Hope it works for you to
Add a comment
So i was playing on my friends Xbox with him and all the sudden (i was playing minecraft in the end with him) the controllers stopped working how i fixed this was i took the batterys out and i pluged my controller into the xbox and it worked (if u unlpug it it stops working)
I hope this helps
Add a comment
Another solution to try.
if the controller doesn’t turn on or stays on. Reset Xbox by pushing and holding the power button until it shuts off. Wait 10 seconds or more.
Connect the Xbox controller to a USB cord (connected to Xbox) ,turn on the Xbox by pushing the power button. When the Xbox is on try to turn on the controller if it turns on great however if it does not simply push the sync buttons on both the system and controller sometimes by holding both the power button on the controller while still trying to sync it. You may have to try multiple times while doing it.
Once it’s done go to your settings, devices and connections, accessories. Once there click the three dots to update the controller as it may need updates. One of the reasons why your controller couldn’t connect to the system
Add a comment
Add your answer
Garrett George will be eternally grateful.
Past 24 Hours: 13
Past 7 Days: 175
Past 30 Days: 924
All Time: 404,817
